Tank sealant CS3204
I used the scotch tape they recommended and it worked just fine. Just a thought if you want to press on.
Where is this tape method you speak of? Don't see it in the vans drawings.
It's mentioned in the current Section 5 revision. It's VHB tape not Scotch though!
If you buy it, get it from Van's. Search for "VHB" and you'll find it.
I used it for all trailing edges on my 10 and it works and is a lot less mess and waiting than the sealant.
Thread drift question
For mechanical bond not fuel related, why would not 3M 5200, 3M firebarrier 2000 and 3M 2216 work. Easy application, vibration damping ( slightly flexible) and bonds to aluminum like crazy ?
