Old 06-05-2019, 03:08 PM
pstraub's Avatar
pstraub pstraub is offline
Default SB 19-03-22, last thing!
Wow, someone named Brad Hamilton decided to close this thread, this was not a Van's bashing, and I wanted to publicly respond to Greg, so here it is....
"Thanks for the response Greg, I appreciate and understand everything you have stated. I trust Van's beyond any other manufacturer I can think of, so the bottom line is.....c'est la vie I have already ordered the replacement pipe as I'm in the middle of my annual. Thanks again for the detailed explanation. Paul"
[ed. Brad Hamilton was a character in the movie 'Fast Times at Ridgemont High', and I closed the thread - had run its course. v/r,dr]
Paul Straub, First Flight May 5, 2017
N917PB, SN 120971
175 hours and counting.....
Old 06-05-2019, 04:45 PM
greghughespdx's Avatar
greghughespdx greghughespdx is offline
Hey there Paul, thanks for the follow-up note! We try our best!
Let me know how it goes once you get the part. Appreciate the feedback!
Greg Hughes - Van's Aircraft - Community, Media, Marketing
Van's web site | Instagram | Facebook
Opinions, information and comments are my own unless stated otherwise. They do not necessarily represent the direction/opinions of my employer.
Building RV-8A since Sept 2014 (N88VX reserved)
Dual AFS 5600, Avidyne IFD 440, Whirlwind 74RV, Superior XP IO-360
VAF build thread - Flickr photo album - Project Facebook page
Aurora, OR (EAA Chapter 105)
Old 06-07-2019, 09:20 PM
VHRV12 VHRV12 is offline
Hi All,
I am affected. I have an EX 00017. I Have done about 15 minutes ground running on the Engine. Preparing for 1st Flight. By the time I convert to Aussie Dollars, apply some GST and freight, its going to cost close to $500.00 Aussie dollars. GULP! I feel a phone call to Vans is in order!
Marcus Bootle.
RV120215. Empenage complete, Wing kit complete. Fuse complete. Finish kit Complete. Engine Kit 80%. 2018 Paid.
http://www.mykitlog.com/users/catego...819&category=0
Old 06-16-2019, 05:26 AM
mike newall's Avatar
This is a simple fix. get a drawing of the doubler, fabricate and tig weld on... Surely
I will contact the Mothership to see what they say, in the meantime, if anyone has input, come back (Scott )
Donated in 2020
Old 06-16-2019, 05:52 PM
bpattonsoa bpattonsoa is offline
For now go with the 25 hour inspection and CO2 detection. The CO2 is always a good thing in a new aircraft and not a bad thing in any plane.
Bruce Patton
Rans S-20 Raven 796S flying since 2019 (slowly)
RV-6A 596S flying since '99 (Sold)
HP-18 5596S flying since '89
RV-10 996S flying since 2014, quick build wing and slow build fues., - dual Skyviews with complete system, two radio and not much else. Interior completely finished with Zolatone. CF plenum. 1624 lbs, FLYING after a 21.5 month build.
Old 08-07-2019, 10:45 PM
magiccarpet's Avatar
magiccarpet magiccarpet is offline
Hi all
I just ordered ordered the exhaust with the doubler from Van's which I will install at next annual just to be compliant.
Just wondering how many of you experienced a crack on that exhaust cyl.#2 and at how many hours.
I now have 25h TT and no crack (of course)
Chris, RV-12 S/N 120832, HB-YSC
Facebook: http://www.facebook.com/magic.carpet.aviation
YouTube https://www.youtube.com/channel/UCLw...nv3vJiqAYoE-dg
=VAF= dues paid for 2020
Old 08-07-2019, 11:01 PM
Hi Chris. If it cracks, it will fail rather quickly and will fail in a way that is significant. I was the pilot on one of two known events. The engineering study shows that same result: Fine until it fails, and then it?s quickly a potentially serious problem. We cannot say that it?s likely or not likely to happen due to the variables involved, but we can say it?s difficult/impossible to predict when it will happen.
On the aircraft I experienced the tube failure on, the engine is a little tougher running than most which may have contributed. Hard to say.
It?s a Pretty quick and easy fix to swap the tube out. Takes Aboitvthe same amount of time as an oil change. I?d strongly suggest not waiting for the next annual. therw just no real reason to wait and plenty of reason to compete it.
Old 08-07-2019, 11:09 PM
Hi Greg
Thanks a lot for your quick and comprehensive reply.
I will do so upon receiving the shipment.
very much appreciated
Chris
