I’m at the point of putting my RV 8 back together and am installing the flaps. Does anyone have pics of which direction the piano hinge pin is installed? Somehow didn’t take a pic before disassembly.
The plans show it coming in from the aileron side in a hole in the mounting bracket for the aileron which is just slightly offset from alignment with the hinge pin line so that the hinge pin will be held in place by the aileron bracket.
Exactly the information I needed and thank you. I scoured the plans in the hangar yesterday and could not find it. I think I’ll blame it on the heat and humidity, but getting close to having a flying airplane again.
There is also a note in the construction manual that it is optional to remove a few tabs from the middle and insert two pins from the middle. That is the way I did my RV-6 23-years ago and followed along with the same on my RV-8 project.
