Old 10-17-2019, 07:41 PM
edward7048 edward7048 is offline
Default coolant hoses
What is the best way to change the cyc. coolant hoses?
Old 10-18-2019, 06:48 AM
Probably the best way is to take old hoses off and then install new hoses in their place?
One of the cylinder hoses is a molded elbow and you will need to purchase from Rotax part distributor ? Lockwood/LEAF. The remaining cylinder hoses are cut from straight length that can be purchased from local auto part store. I would buy high-grade silicone hose.
EAA #499867
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 610
LSRM-A Certificate 2016 for RV-12 N633CM
Old 10-20-2019, 09:35 PM
I bought automotive 5/8? heater hose and a molded elbow to replace mine. The specs were something like 350F and 50 psi on them, and I found them online at an auto racing shop.
