Old 11-17-2019, 09:44 AM
bobg56 bobg56 is offline
Default Weighing RV12
I'm the third owner of an RV12, I would like to weigh and recalculate the W+B, I know to drain fuel and remove non essentials, my question is what type of scales were used? ...thanks
Old 11-17-2019, 11:02 AM
DaveWelch DaveWelch is offline
Default Scales
I was fortunate enough to have a hangar neighbor who owed a set of 4-channel scales he uses for weighing his race car(s). I believe there are some discussions about this if you search the forums. Many ways to do it even with just one scale rotated among the three wheels.
Followup...search the forums for "weighing" and "scales". Also get a copy of the RV-12 Production Acceptance Procedures (PAP) for the -12. I'm pretty sure that's where the procedure is.
Good luck!
Dave
RV12 N951DZ
First Flight 9/23/16!
No paint yet. Working on a scheme with John Deere colors or accents.
Old 11-17-2019, 12:52 PM
I'm wondering if regular digital bathroom scales cane be used or something else designed for aircraft weighing is required.
Old 11-17-2019, 02:14 PM
Mich48041 Mich48041 is online now
Some bathroom scales shut off after a minute. That does not give enough time to read the weight before it disappears.
Joe Gores
RV-12 Flying
Old 11-17-2019, 03:01 PM
Jamesey Jamesey is offline
Default 😂
Mine don?t. They protest for hours afterwards.
Old 11-17-2019, 03:07 PM
joedallas's Avatar
joedallas joedallas is offline
Default Use two good quality bath scales
Put blocks of the same height of the scales on a level surface under the main wheels and one scale under the nose wheel and record the weight, then remove the first scale and re-weigh with the other scale.
If the weigh the same it should be a good number.
Repeat under each main.
Joe Dallas
Joe Dallas
Kit-#12400
www.joesrv12.com
www.EAA1298.com
Old 11-17-2019, 03:18 PM
bobnoffs bobnoffs is offline
i think weighing with one scale is fine [that's how i did it] but remember to block up the 2 wheels not being weighed the thickness of the scale to keep everything level at each weighing
Bob Noffs
n. wi.
dakota hawk/jab 3300 built and flying. sold 6/18.getting serious about the 12. in the hangar now as of 10/15/19
RV-12 kit as of 9/13
Old 11-17-2019, 03:34 PM
Default Not necessarily
These days, even moderately priced scales are usually very repeatable, but not necessarily accurate, so two scales of the same model/manufacturer are likely to read the same, even if not accurate. Better if you can find one high quality scale to compare with. Many EAA chapters have some you can rent or borrow.
Also be sure to relieve any side pressure from the gear legs. In principle this shouldn?t matter, but with real-world scales it might.
Old 11-17-2019, 07:11 PM
I used bathroom scales. I had three and took three readings rotating the scales so that I had one earring from each scale at each wheel. Then I averaged the three readings at each position for the aw&B calf. I reasoned that would average out scale errors.
Old 11-17-2019, 07:12 PM
?Reading? not ?earring?. Don?t ya love spellcheck!🧐
