Old 09-10-2019, 03:08 PM
burgundyja's Avatar
burgundyja burgundyja is offline
Default Need help trig tt22
I just got the trig adsb bundle. I installed it and programed it but I am not getting any gps signal. After about 5mins I get a no gps warning. I have gone over the wiring 3 times. I do have 4.95 volt at the GPS cable. I have emailed trig support and they said it must be in the wiring and to email them after I find the problem. Is there a way to test the antenna? And yes I pull the airplane outside when I test it.
Mike Johnson
8A N484M
Old 09-10-2019, 03:44 PM
Walt's Avatar
Walt Walt is offline
Suggest you make sure the setup configuration is correct.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 1700+ hrs, New Titan IO-370, Bendix Mags
Old 09-10-2019, 03:59 PM
Patcullen550 Patcullen550 is offline
Default Qma connector
Center conductor on qma connector needs to extend beyond the cup portion of connector. This was difficult for me to fabricate. Double check programming .good luck Pat
