AP Disconnect wires
KALEWIS
Just installed the skyview AP knobs - the AP disconnect wires are different than the old setup. The wiring diagram shows the more recent connections. I have red white and 2 black wires from the disconnect panel button. The new wires are black white yel/grn and purp/yel coming from the knobs via skyview.
Anyone have a reference for that ?
Thanks !
Turn master switch off.
While the AP disconnect button is held pushed in, use an ohmmeter to
determine which two of the 4 wires coming from the button have continuity.
The white and one of the blacks should have continuity (less than one ohm).
Connect those two wires to the SkyView Knobs white and black wires. Connect
the Red wire to the Yellow/Purple and connect the remaining black wire to yellow/green.
