Old 10-08-2019, 09:49 AM
Moeggeploeg Moeggeploeg is offline
Default Flying the RV 8, how about the 14
Recent postings on flying/landing the RV 8 got me wondering what speeds/configurations/trim/flaps/prop RPM etc you use flying your -14.
Descend settings for RPM/MP/flap say for ex. 500 fpm descent rate?
Speed, settings for downwind, base, short final?
Power off landings or carry some power?
Entry speeds, pitch, G pull for aileron rolls and loops. Tim O wrote a bit on the latter some time ago.
Your feedback much appreciated.
Old 10-08-2019, 11:19 AM
control control is offline
I only have 10 hours on my 14 so far. Interested in the values of others. The below is from the log of my last flight.
In general this final was flown at 75kt slowing to 70 above the numbers. MAP at 14'' and the rpm was set to full forward but gave me 1600. I got more like 700-750 fpm with these settings, flap 30.
This felt like a good VMC/VFR final when you have a long runway and the taxi exit to use is long down the runway. This time I had no power when I started to flare but sometimes I dont fully cut power until touch down.
We have plenty of instruction at my airfield, to fit in, I aim for 90/80/70kt for downwind/base/final whenever there is other traffic in the pattern.
RV-14 kit #140138
Flight testing
Http://magnusrv.blogspot.se
Old 10-08-2019, 11:56 AM
mturnerb mturnerb is online now
I use numbers from Mike Seager which work well and I've adapted my pattern / approach numbers somewhat from his.
Takeoff full power and RPM. Established in climb and above 700 feet or so, reduce RPM to 2500 and power to 25". Cruise 2300 RPM, 23" (sometimes I'll push that up but little gained for the fuel flow increase).
Approaching the pattern, 2300 RPM/16" which is around 120 - 130Kts. To slow down entering the pattern, power back to 12" or so, hold altitude until indicated airspeed is 100kts, first notch of flaps (-3 to 0 degrees). Either now or established on downwind, I push prop full forward and complete GUMPS check including brake check/fuel pump/mixture.
Entering downwind (or midfield if in pattern after takeoff), trim for 95 kts or so, prop full forward, power to maintain pattern altitude.
Abeam the numbers, second notch (15 degrees) flaps, 1800RPM, trim for 85 kts. This will give you a descent rate of about 500FPM. Turning base, last notch of flaps (30 degrees), trim and maintain 75. Turning final, adjust power to maintain desired glideslope and speed - 75kts. I've gotten comfortable slowing to 70 or so on short final depending on wind.
Some folks will prefer last notch of flaps turning final but I try to fly it tighter so I like to get that out of the way. I fly at a towered field: my "patterns" are often non-standard so I adjust accordingly.
Turner Billingsley
RV-14A built/sold N14VB
RV-10 in progress as of May 2020
https://tbrv10.blogspot.com/
Old 10-08-2019, 12:14 PM
KleensRV6's Avatar
KleensRV6 KleensRV6 is offline
Default Try it with an AOA
If you have an AOA calibrated check your AOA, particularly base to final. You may be surprised at your numbers.
Jailbird/CW Kleen
RV6 KGIF
Donor through 2020
Old 10-08-2019, 12:53 PM
My AOA "comes alive" as I slow to 70-75kts and gives a nice indication of lift reserve as I slow over the runway.
Turner Billingsley
Old 10-14-2019, 03:32 PM
Default RV 14 speeds
Thanks for the feed back.
Some numbers to get going. Needs fine tuning for sure.
Cruise: 23" MP/2300 RPM, Fuel flow 9 GPH. Flaps: minus 3 degrees.
Descending: MP 16"/2300.
Slowing to the pattern: MP 15"/2300/pitch for 110-120 kts then 95 kts.
Abeam the touch down: Throttle to idle, Pitch for 75 kts, Mix rich, Flaps to 15 degrees (as soon as under Vfe 100 kts) and feed the Throttle in to 1800 RPM, trim.
45 degrees: Prop full forward, Flaps to 30 degrees and start descending turn for base leg.
Power closed as RWY made. Fly 75 kts down to leveling out.
Take off: Flaps zero (15 degrees for short or grass), Mix full rich, Prop FWD, WOT. Pitch 12.5 degrees, Vy 95 kts.
Climb out: 25/2500 RPM, Flaps to zero.
Old 10-14-2019, 03:54 PM
Excellent post - I forgot to mention flaps and flap retraction on takeoff. I have switched between around 10 degrees flaps and no flaps on takeoff, still trying to decide which I like better. We have slightly different techniques in pattern but similar power and speed settings. I'm going to try it your way when I get her out of the paint shop...
Turner Billingsley
Old 10-14-2019, 04:15 PM
bkervaski's Avatar
That 75kts on final really makes a difference. It lands like a butterfly at that speed. I spent my first 50 hours landing too fast.
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 10-14-2019, 04:20 PM
Nova RV Nova RV is offline
90 kts downwind flaps 0, 80 kts base flaps 15, 70kts final flaps 30.
Easy peasy with prop and mixture full fwd entering downwind so not a lot of rpm or manifold pressure numbers to memorize. Prop fwd and adjust power to maintain desired speeds.
Chris Moon
Leesburg, VA
CFI-I ASMEL, ATP
RV-14A kit # 140243 (flying as of 11/18)
www.mykitlog.com/chrismoon/
