Go Back   VAF Forums > Main > My RV Build Project
  #41
Old 11-01-2019, 10:50 PM
dreed dreed is offline
Awesome - in its natural home. Looks great!
Dan Reed
Camas, WA
RV-7A - Slider in progress - N167DR (reserved)
Working on finish kit/cowl
2018 and 2019 VAF dues paid
Old 11-02-2019, 10:58 AM
scsmith scsmith is offline
YeY!
It was just about 8 months ago (march I think) that I visited and you thought a hangar move was imminent. I think you will find it a mixed bag. Your work is more efficient because you have more space, and it takes some focused effort to go to the hangar (although you are so close it almost doesn't matter), but you can't just walk out to the shop and putter for a few minutes in an evening, head-scratch the next challenge, etc. Net I think it is a plus, because it focuses your work.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
Old 11-03-2019, 09:33 AM
wjb's Avatar
wjb wjb is offline
Thanks Steve! Happy to finally be at the airport. I hoping for < 6 months to completion. It will be a workflow transition for sure. I won't have all the resources, like running water. It will take some time to settle in.
Come and visit any time!
Bill Bencze
N430WB RV-7 #74152 @ KHAF, tip-up; IO-360-M1B; Hartzell CS. !! Phase 1 !!
2357 hrs over 8.5 years to get to flying. Log at: http://rv7.wbencze.com
VAF 2020 donation happily made
Old 01-29-2020, 08:32 PM
wjb's Avatar
wjb wjb is offline
Default I grew wings!
In the dark and cold of California winter nights, we found this bird has grew some wings. Close tolerance bolts are in; no going back now! Thanks to fellow RV-7 driver Pat to help with the wrangling and wiggling to get the bolts in. A little bit of persuasion from the rivet gun to get the bolts home, and now WE GOT WINGS!
Also ... free to a good home: rolling wing stand, lightly used (often on Sundays, after Church)
Bill Bencze
Old 03-29-2020, 07:31 PM
wjb's Avatar
wjb wjb is offline
Default First engine start!
Finally the fateful has arrived to see if all this assembly of airplane parts actually can actually make airplane noises.
I went through all the pre-oiling procedures discussed here on VAF and in the Lyc docs, tested for good oil pressure, fuel pressure, fuel flow, the whole nine yards. All good.
Towed the plane to the nearest pad that had a pad-eye, tied her down, hooked up a car-sized battery in lieu the little Odyssey - in case there were lots of cranking involved
Turns out that the external battery was soft and it had a hard time turning the engine over with the plugs in. However, it only took one blade to start once it got around and then we're off the the races!
Obligatory evidence:
https://www.youtube.com/watch?v=T6wuyqh9ejE
Only significant issue is that the CHT2 reads about 10% below the rest, but tracks well the other 3 well. No CHTs on this run above 275 F. EGTs track tightly.
And, I found that the Andair fuel pump is a noisy beast when the pressure comes up. It purrs like a kitten with no load during fuel flow testing, but it's quite noisy when pressure comes up. You can clearly hear it in the video prior to the start. Anyone else have this experience.
First flight getting closer!
Bill Bencze
Old 05-30-2020, 12:36 PM
wjb's Avatar
wjb wjb is offline
Default Airworthy!
There's a time for all good things to come to an end.
Time to stop the building; time to start the flying!
I received my airworthiness certificate yesterday, a great way to kick off the weekend. Our local DAR, Richard Ortenheim (Skyview Aviation, KTCY), had to drive over since the field was low IFR that morning. We pre-prepped all the paperwork via email prior to the inspection. The inspection went well; no significant issues were found -- and all jam nuts were tight!
I requested and received a large Phase 1 test area (in magenta below) south and east of SF Bay Area, which conveniently includes Harris Ranch, a popular and delicious fly-in steak place in the Central Valley (you can drive in, too). Don't know when in the program I'll make it down there, but it's a good option to have!
Just need to finish up some transition training and wait for fog-free weather.
Thanks to everyone here on VAF that made this build possible; this is an invaluable resource and you are a wonderful community.
Bill Bencze
Old 05-31-2020, 09:18 PM
jetmech's Avatar
jetmech jetmech is offline
Congrats on getting her done Sir!
10" HXr GRT's Safe-fly 2020 with Echo ADSB
TMX REDGOLD IO-360/Dual EFII
RV-3a/o-320 Old School style Brada
Speed is life! Bank it & Yank it for the G's
Dues paid 2020 thxs again DR!
Home base -o88
Team Light Aviation LLC.
Old 06-19-2020, 09:10 AM
wjb's Avatar
wjb wjb is offline
Default First Fligh: 17 June 2020
Link to first flight post:
http://www.vansairforce.com/communit...d.php?t=183718
Bill Bencze
