Old 07-07-2019, 04:01 PM
dreed dreed is offline
Default Anyone use the Matco Intensifier kit?
Hi All-
Since I ordered the new 7A mount/nose gear I have been looking at other options/upgrades while I wait for it.
I have the Beringer nose wheel and it is gorgeous and have been pondering their mains/brakes too. I see that Matco has a sleeve kit that would get the original master cylinders to the same bore as the Beringer ones and save me ~$1600 or so and quite a bit of time. The Beringer stuff is beautiful and if money and time were no objects it would be a no brainer but...
http://www.matcomfg.com/MASTERCYLIND...v-3282-46.html
Has anyone tried this or have any experience with them? Looks like I could use this, then would only need to build new lines from the external connections down to the wheels.
Thanks!
dan
Dan Reed
Camas, WA
RV-7A - Slider in progress - N167DR (reserved)
Working on finish kit/cowl
2018 and 2019 VAF dues paid
Old 07-07-2019, 05:48 PM
Have people with A models been running out of braking performance, with excessive pedal pressure needed?
Old 07-07-2019, 06:08 PM
hey Charlie- I was thinking of using this in conjunction with the Beringer wheels/brakes for a couple reasons on the wheel/brake side without replacing the master cylinders and plumbing in the cockpit.
The Beringer masters are .5" bore. The kit converts the standard Matco masters to the same size and therefore should be the correct pressure ratio for the Beringer calipers. I wouldn't use them on the standard calipers.
The reasons I am interested in the Beringers include:
Tubeless
Ball vs. taper bearing
Easier servicing
Dan Reed
Camas, WA
Old 07-07-2019, 06:17 PM
Ahh... makes sense. I really hate dealing with the Cleveland bearings at annual, and tubeless would be great, too. I've got a pair of old 6x6 pulloffs from a Citabria running tubeless on spun aluminum one-piece wheels on a Kolb Twinstar, & haven't added air in two years.
Charlie
Old 07-08-2019, 05:29 AM
Timberwolf Timberwolf is offline
I?ve used the intensifiers multiple times. They work great and are cheap. I?m using them on planes with Bushwheels to help correct for some poor geometry in the master cylinder setup.
Shane
RV-6 IO-360 Angle valve, G3X touch
Murphy Moose M14P flying
Aero Engineer, A&P
Old 07-17-2019, 09:34 PM
Thanks Shane! Somehow missed your reply. Good to hear!!!!
Dan Reed
Camas, WA
