Old 05-09-2019, 08:44 PM
jcarne's Avatar
jcarne jcarne is offline
Yep I screwed up this area a couple of times on my -7A. No joke about that extra trim tab skin Mark mentioned, I know few that have made it through it in one shot.
Jereme Carne
PPL
RV-7A Emp. done
Wings done
Fuselage done
Finish kit almost done
Exempt but gladly paying!
Old 05-11-2019, 11:25 PM
Roarks's Avatar
Roarks Roarks is offline
Thanks for the heads up on the trim tab skin... I will be extra diligent.
Good news... getting parts from Vans only takes 2 days! So I was back up and running today.
Hopefully this may help someone... don't do what I did!
so moving on!--------------------------------------------------------
Okay edge prep... Wow I knew it was going to be annoying but I had no idea. I have a scotchbrite wheel on my bench grinder but I don't trust myself. I tried with my scrap part and ZIINGGG I managed to hit the face and not the edge not once but TWICE trying to clean it up.
So I tried this...
Ordered the paper from amazon. 100 sheets of 400 grit for like $20 dollars... so far I love it.
Also I happened to discover that my Avery rivet gage happens to be perfect for tracing out a R.25...
Went to go shape it using abrasives but when the part got hot enough the sharpie mark disappeared... I said NOPE. I don't want to effect the heat treat on that part. So I stopped.
Now I'm waiting for my new bandsaw stand to show up. I already have a Milwaukee portaband so I got a stand that converts that into an upright bandsaw with a table. Hopefully that works out.
Old 05-12-2019, 06:52 AM
ksdflying ksdflying is offline
Those sand paper discs you have will be your ticket to success. Someone nudged me tribal knowledge to get foam sanding blocks. The soft sand block gently and nicely allows the sanding surface to fold around and edge, not too much, not too little....insert the word "finesse" here.
Extra tip....look at part's and skin's edges for excessive burr; often I GENTLY run a edge debut tool (V-style) along the edge once or twice, then apply the sanding block.
Try this, and I think you will be happy, get a small hand towel, fold it perhaps once...your sticky backed sanding discs will stick to that nicely....essentially imitating a foam style sanding block.
Short answer...thin part's edges...use sanding. The wheels, die grinder or bench grinder...both will cause you headache. Those two tools are for thick parts, holes, or small w many flange type parts.
Dan K. RV-8 kit purchased 2014, build start Jan 2018, Slow build Emp. done - March 2018, Slow build Wings done -Oct 2018, QB Fuselage started - Sep 2018
Avionics in - April 2019. Engine and Finish kit in hand 2019.
VAF dues paid!
Old 05-14-2019, 09:09 PM
Roarks's Avatar
Default Cleco caps.
So... I ran out of my clecos that have caps... borrowed a friends. To my shock I couldn't believe how easily some of them scratched the skin!
Intolerable to me.
I just got a new pile of clecos and went to go buy more caps... yeah ATS stopped stocking them and yardstore wanted $.30 each!?
I found this guy...
https://www.youtube.com/watch?v=aft8JSct35A
The mcmaster.com part number is 9753K16 which he didn't mention. $~4 for a pack of 100. Just gotta poke the hole.
Old 05-15-2019, 06:34 PM
wirejock's Avatar
wirejock wirejock is online now
Intolerable to me.
I found this guy...
Cheap. Easier than mine too.
https://drive.google.com/open?id=1yc...rm91abzI42PWP-
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 12/03/2019, plus a little extra.
Disclaimer
Old 05-16-2019, 12:03 PM
rv7boy's Avatar
rv7boy rv7boy is offline
Forum Peruser
Default Flood of orders
The mcmaster.com part number is 9753K16 which he didn't mention. $~4 for a pack of 100...
And today someone at McMaster-Carr is wondering why there is a sudden flood of 825 orders for that part number.
But we know why.
Don Hull
RV-7 Wings
KDCU Pryor Field
Pilots'n Paws Pilot
N79599/ADS-B In and Out...and I like it!
?Certainly, travel is more than the seeing of sights;
it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
Old 05-16-2019, 05:35 PM
Roarks's Avatar
So I just outfitted 125 1/8 clecos... That was tedious. Luckly my 9 month old sat in my lap and would hold anything I handed her. So we were swapping out cleco pliers and the awl.
I'm not a fan of how the guy in the video did it.
The wood block with the hole in it helped... but I put the cap "up" and eyeballed center. Worked better for me.
I still have 275 3/32 clecos on backorder with brown tool. So I ordered a leather hole punch. One of those rotary things with multiple sizes. I'm going to try that instead of just poking a hole... there is a drip nib on the end of these I would like to remove.
Old 05-17-2019, 11:18 AM
Roarks's Avatar
Alright I'm ecstatic now.
here's what to do:
Amazon number -> ASIN: B07D28DBC6
Old 05-19-2019, 12:33 AM
Roarks's Avatar
Well... Finally got the bandsaw table set up and cut the spar reinforcements.
I wouldn't recommend anyone do this outright.
I justified it because I already had a Milwaukee portaband... probably one of the most bada** consumer grade tools out there. Swag offroad makes these tables for them (and other brands) and I gotta say... VERY nice. Probably much higher quality than any stand up bandsaw for less than $1000.
Old 05-19-2019, 06:20 AM
Taltruda Taltruda is offline
Default SWAG bandsaw table
I love my SWAG bandsaw table! I bought a cheap $99 harbor freight version of the portable bandsaw just to have the same setup, and I love it! (Just very loud) I also have a cheap Craigslist $90 standalone bandsaw for most aluminum cuts. (Very quiet) I think it?s plastic frame Delta model, and although it?s band speed is too fast for cutting steel, with a fine tooth blade, it cuts aluminum easily! I reserve the SWAG setup for heavier steel cutting in the shop.
Tom
Las Vegas
RV-8 empenage almost finished
Horizontal Stab done! 2-15-2020
Vertical Stab Done! 5-27-2020
Rudder Done! 5-31-2020
Wings ordered!...
