Old 11-18-2019, 09:15 AM
kentlik's Avatar
kentlik kentlik is offline
Originally Posted by jcarne View Post
Yep I used the stuff that Van's sells. Just a replacement for the old. Works great.
Roger that! I have to get down there today for some parts, so I will pick up a small kit.
Kentlik
RV-7A in progress
http://www.imdb.com/name/nm0527486/?
Private pilot, ASEL!
EAA 105 Chapter 7S3
Bi-annual financial contributor
"The credit belongs to the man who is actually in the arena..." Teddy Roosevelt
Old 11-28-2019, 09:47 AM
kentlik's Avatar
Default Pitot
I had a bit of time and ran my AOA and Pitot lines. Hope this works as not sure of the throw of elevator bell crank...
[IMG]pitot by Kent Luttrell, on Flickr[/IMG]
[IMG]pitot2 by Kent Luttrell, on Flickr[/IMG]
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 11-28-2019, 10:24 AM
jcarne's Avatar
jcarne jcarne is offline
Looks pretty good there brother! I think you should have plenty of clearance, good idea supporting it close to that radius too.
Jereme Carne
PPL
RV-7A Emp. done
Wings done
Fuselage done
Finish kit almost done
Exempt but gladly paying!
Old 11-29-2019, 11:23 AM
kentlik's Avatar
Thanks, Jereme! I had looked around at other designs and this seemed a good fit for my plane. The radius fittings at the bottom seemed the best solution if I could control it without too much hardware. Slow but steady...
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 12-19-2019, 04:43 PM
kentlik's Avatar
Default servo brkt
Got some time away from figuring out electrical to pound a few rivets. I had to use some existing holes for the servo brkt so not quite even but it will work just fine.
[IMG]IMAG1003 by Kent Luttrell, on Flickr[/IMG]
[IMG]IMAG1030 by Kent Luttrell, on Flickr[/IMG]
Over drove one, maybe two but it will be ok, rivets were a bit long...
[IMG]IMAG1033 by Kent Luttrell, on Flickr[/IMG]
There are marks from my pen on the angle, it doesn't look too good but I doubt anyone will see them.
[IMG]IMAG1031 by Kent Luttrell, on Flickr[/IMG]
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 01-03-2020, 07:15 PM
kentlik's Avatar
Very initial panel ideas. Disregard the round gauge designations. One will be for the SDS programmer. The others are TBD. I have both an airspeed and altimeter gauge that may or may not be used.
[IMG]IMAG1008 by Kent Luttrell, on Flickr[/IMG]
[IMG]IMAG1044 by Kent Luttrell, on Flickr[/IMG]
[IMG]IMAG1047 by Kent Luttrell, on Flickr[/IMG]
[IMG]IMAG1043 by Kent Luttrell, on Flickr[/IMG]
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 01-07-2020, 06:49 PM
kentlik's Avatar
Default SDS
Decided on left placement of SDS programmer. Hole placement set for GRT MINI X or other in the future.
[IMG]IMAG1050 by Kent Luttrell, on Flickr[/IMG]
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 01-08-2020, 06:48 AM
jcarne's Avatar
Let it begin!
Jereme Carne
PPL
RV-7A Emp. done
Wings done
Fuselage done
Old 01-09-2020, 08:36 PM
kentlik's Avatar
Let it begin!
Yes, it begins...
I am piecing together an idea and following a simple plan of one bite at a time.
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 01-29-2020, 01:12 PM
kentlik's Avatar
Finalized and installed fuel manifold and lines
[IMG]IMAG1107 by Kent Luttrell, on Flickr[/IMG]
[IMG]IMAG1088 by Kent Luttrell, on Flickr[/IMG]
[IMG]IMAG1083 by Kent Luttrell, on Flickr[/IMG]
[IMG]IMAG1097 by Kent Luttrell, on Flickr[/IMG]
[IMG]IMAG1110 by Kent Luttrell, on Flickr[/IMG]
I have to finish the cover but was able to use the stock pump bracket deal and just segment it a bit and whola!
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
