Go Back   VAF Forums > Main > RV Building Tips/Techniques
Old 11-22-2019, 09:43 AM
RViator60 RViator60 is offline
Default How to form #40 dimple in inaccessible location
I need to form a dimple in a #40 hole that I can't access with squeezers. Is there a tool or technique for forming a dimple in a remote location?
Old 11-22-2019, 09:44 AM
rocketman1988 rocketman1988 is offline
Default here ya go...
http://www.cleavelandtool.com/3_32-C.../#.XdgQZS2ZO3c
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
ShowPlanes Cowl with Skybolts Fitted - Beautiful
Wiring...
Dues+ Paid 2019,...Thanks DR+
Old 11-22-2019, 09:45 AM
scard's Avatar
scard scard is offline
Sure is. There is a blind dimple tool
https://www.aircraftspruce.com/catal...4aAtMdEALw_wcB
Scott Card
CQ Headset by Card Machine Works
CMW E-Lift
RV-9A N4822C flying 2200+hrs. / Cedar Park, TX
Old 11-22-2019, 10:54 AM
MS1095 MS1095 is offline
There is also this option if you have room.
https://www.aircraftspruce.com/catal...?clickkey=6499
I have found that the pop rivet dimples do an OK job at best, especially in SS.
YMMV.
Old 11-22-2019, 11:23 AM
RVDan RVDan is offline
If hard pressed, I use this tool then, machine CS a touch to flush the rivet.
Dan Morris
Frederick, MD
PA28-140
Hph 304CZ
RV6 built and sold
N199EC RV6A flying
Learn the facts. "Democracy dies in darkness"
Old 11-22-2019, 03:40 PM
Thanks for the quick feedback! Really appreciated.
Old 11-22-2019, 11:30 PM
lr172 lr172 is offline
YMMV.
I made two holders for the dimple dies (from 1/2" steel rod) and use a rivet gun with mushroom head and bucking bar with them. It is easy to ruin the tip of the die if you are not carefull though. But I like the pop rivet tool on thin sheet stock.
N64LR - RV-6A / IO-320, Flying as of 8/2015
N11LR - RV-10, Flying as of 12/2019
Old 11-23-2019, 08:22 AM
John Tierney John Tierney is offline
And this option: https://www.aircraftspruce.com/catal...BoCEO0QAvD_BwE
John Tierney
Vonore, TN
RV-7A - N777JT Flying
Old 11-23-2019, 08:48 AM
RandyAB RandyAB is offline
YMMV.
I like these but in my experience you have to really make sure that the pressure is dialled quite low lest you create smileys.
______________________
Randy P.
1st time builder
RV10 - QB wings and fuse. Working on cabin top
St. Albert, Alberta, Canada
Reserved:C-GRPY
