Old 09-30-2019, 06:08 PM
ringlasergyrosandwich's Avatar
ringlasergyrosandwich ringlasergyrosandwich is offline
Based on this feedback as well as discussions in the other thread, I decided to order the Cleaveland RV-14 tool kit. In addition, I ordered a 20 gallons compressor. I'm thinking about whether I will want to get the drill press, bench grinder, and band saw. Perhaps I will wait until I need them and talk to more 14 builders.
Also, the documentation that came with the RV-14 crate, Empennage Packet, says, "Steel parts, if not powder coated, should be oiled or primed immediately." The majority of the parts are obviously aluminum, but there are a few parts that are not covered in that blue material. I went over them with a magnet but none of them reacted... is that an adequate test to validate that I don't need to oil/prime anything from the RV-14A empennage kit?
In other news, I completed my second EAA 1000 workbench. The second one was much easier because I had the first one to put the project on!
Old 09-30-2019, 06:28 PM
Girraf Girraf is offline
I bought my tools separately. Don't know if that was cost effective but it avoided buying things in a kit that I didn't want. Jason Ellis (palamedes here on VAF) put together a tool list that I used to get going. It was based on the Van's recommended list but had his commentary on whether it was required vs optional, and when in the build he needed it which made it easy to defer buying some items until I needed them.
I have yet to receive a steel component that isn't powder coated. I suspect that statement is a holdover from a time when steel parts did occasionally ship naked. As for the aluminum, all of the real think aluminum doubler plates (the 1/8" think and greater) and angle iron should be primed.
RV-7:
Empennage complete!
Wings in progress
Old 10-01-2019, 07:45 PM
Since funding isn't currently a problem (that may change later ) I ordered the RV-14 Tool kit from Cleaveland, as well as a 20 gallon air compressor from Harbor Freight.
I finished assembling my second EAA 1000 workbench. Next thing I need to do is take another look at my aluminum empennage components since the steele ones are already powder coated, and decide what to do about it. I have oil I could apply to protect them, since I have no idea at this point what I'm going to eventually do about priming. I didn't realize I was going to be on a clock for that one until after I received the kit.
edit: Also, I'm logging my efforts and costs using eaabuilderslog.org
Old 10-03-2019, 05:30 AM
Electrogunner Electrogunner is offline
Default LEE
I flew into Lee last Sunday with my -10 and picked up a friend of mine to go get his plane down near NC. Great little airport.
RV10 N620RV
IO540 C4B5
Whirlwind 375RV prop
Garmin G900X
First Flight 2/14/2019
Old 10-05-2019, 08:26 AM
I realized my knowledge regarding priming is very deficient, so after reading through the documentation provided to me by Vans, I created this thread in the Priming section: http://www.vansairforce.com/communit...d.php?t=175790 I'm sure I'm not the only new builder with questions like these, although I'll admit I'm proper in the lower quartiles
It's a good location (walking distance to downtown Edgewater) but you need to be on top of your short fields.
Old 10-05-2019, 11:41 AM
wcalvert wcalvert is offline
Default Build on...
Dude, no one has said this yet, but they will... "Build On!"
Don't let all this bog you down right from the start and keep you from enjoying the journey. There will be plenty of questions and none of this will "kill" your project.
Enjoy!
Wb
RV-7 Tipper
Bill (Wild) VA-165 '90-'93
Anacortes, Wa
Start 2/19 Emp complete 4/19 Wings complete 11/19 Fuse complete 6/20 Finish kit in the shop 6/20.
Old 10-05-2019, 03:23 PM
Good call. My kit didn't come with an air-powered drill so I actually need to get one of those. Any difference between 2600 and 4000 rpm? They are both within Vans' recommendation. Also, I've read online that it's worth paying extra for the keyless chuck... any downsides, besides cost, to going keyless?
I've completed step 1 of the empennage which involved placing two clecos! Need to match drill next while I figure out the primer I will use and which items need to be primed.
Old 10-11-2019, 11:11 AM
kmbusse kmbusse is offline
Another builder I know just used a cordless or corded drill for his entire build and was happy not getting an air drill, so I did the same and have been perfectly fine without. Besides I hate listening to my compressor, so the less time it?s working makes me happy. Radio is much better company than a compressor.
Old 12-23-2019, 06:31 PM
Made some improvements to the workshop and acquired more tools. I did some practice projects but have finally started working on the plane.
I completed empennage page 6-02 without issue, but on 6-03 I accidentally scraped a bit of white powder coating off of a hinge bracket. The drill bit was a bit too short and I didn't realize, then the chuck scraped against the highest point on the bracket. The structure of the bracket seems fine, but the powder coating is opened up. I'm guessing I need to do something about this since the metal is exposed along some scratches now. Can I paint over it with something, do I need to replace the bracket, or something else?
Thanks. Looking forward to making good progress now!
edit: I've moved the question to the primer forum here: http://www.vansairforce.com/communit...5&postcount=15
Old 12-31-2019, 04:08 AM
RV10Man RV10Man is offline
I scratched some powder coating off in a few places. I just painted over it a built on.
RV9A under construction--N781DM reserved
Donated
