Old 01-11-2019, 08:48 AM
leok leok is online now
Hey Ken,
Here is my thought process to answer your question on why I show the "switched battery buss" connected directly to the battery and fed through a DPDT "Master Switch" instead of through the master relay.
The key is that I have dual electronic ignition rather than magnetos. For that reason I needed a direct from the battery feed for one of the ignitions. No relays that could fail in flight. I also need the ignition to be off when the master is off, so no independent separate power switch to the ignition. Since the master will typically only be switched on/off on the ground, I will always know if there is a switch problem before I fly. It is highly unlikely for a switch to fail while in the on/off position without being cycled. When the master is off, I always know the ignition is dead/off.
The other loads tied to the "switched battery buss" are all loads I might want live with only the master on (i.e. prior to engine start) and also do not want going through the VPX (another possible failure point). I suppose you could make the argument that I could add another battery buss fed by the master relay moving all other loads there so the power did not flow through the switch. That would relieve some load from the switch contacts.
Anyway, as always I am willing to be schooled by others.
Building started Oct 5th 2014, Flying since 1/16/2020
http://www.mykitlog.com/leok
RV Hotel, come by and visit if you're in town
Dues paid 2020
Old 01-11-2019, 09:55 AM
Hi Leok,
Forgive me if you've already dealt with this, but one thing caught my eye in that post: 'I also need the ignition to be off when the master is off'. Does the system include a 'smoke in the cockpit' procedure? Traditional action for smoke is typically 'master off' first (engine continues to run), then if smoke clears and comfort zone allows, try to find the culprit. Though troubleshooting is best left for ground ops.
If a typical pilot suspects fire in the cockpit and instinctively flips the master off, does your engine stop?
Charlie
Old 01-11-2019, 11:21 AM
Default Blind spots
Charlie,
I have done a lot of technical writing, product and production system design in my career and have found there will always be someone with a different perspective or greater knowledge in some area that will point out something you didn't think of. That is one of the reasons I put this thread out there ... well
You are correct. In the design as it stands (and is already mostly in place, but can be adjusted) there is no way to turn off the master and keep the big noisy fan going. And I agree master off, is one way of quickly killing all electrical quickly. I don't fly big high end stuff so I'm not sure if that would apply to more complex aircraft.
So now I need to ask myself is what I have acceptable? Much better to work through possible responses in my shop than in the air. This is one I dismissed (and perhaps should not have) since every circuit is protected by a fuse or electronic CB. What would be the response with smoke of unknown origin in the cockpit? Rather than trying to reason it out here, I appreciate the comment and will look hard at what I have to see if I should make some changes.
Dues paid 2020
Old 01-11-2019, 11:38 AM
lr172 lr172 is offline
I just went through this and ended up with three busses and three switches. A master bus, an avionics bus and an ignition bus. In case of a fire or problem, the master goes off, leaving me avionics and ignition. If not solved, the avionics bus goes off, leaving only the ignition with power. In my case, each bus can be separately switched from Left, Right or both batteries: I am using relays/contactors.
I would not want to be without a way to kill everything except the ignition, being ignition dependant. &$*^ happens and you need a way to isolate things if you want to keep the fan spinning with dual EI.
N64LR - RV-6A / IO-320, Flying as of 8/2015
N11LR - RV-10, Flying as of 12/2019
Old 01-11-2019, 12:39 PM
BMC_Dave BMC_Dave is offline
I'm also going through the same planning process. I think I've settled on a dual bus, dual alternator, single battery system. Primary and endurance bus, with the e-bus only hosting all bits to keep the fan spinning (and pitot heat) and an alternate feed path to the battery. This does mean that an emergency requires you to close 'E-BUS ALT FEED' before turning off the master.
I'm considering the effects of leaving the relay-controlled alt feed closed in normal operations, allowing you to shut off the master with no effect to the engine. So far I can't think of any downsides to this but I'd be happy to hear what others think. ETA: http://forums.matronics.com/viewtopic.php?p=195860 Looks like this was already discussed and determined to be fine
Old 10-14-2019, 11:42 AM
Default A few updates to this thread
Two updates to my earlier posts.
Keeping the engine running with electronic ignition when the master has been turned off is resolved. I went with the CDI-2 system with the back up battery. With total loss of the buss power the CDI-2 switches to it?s own back up battery. I can restore ship power by turning on the E-buss to extend the CDI-2 battery, or leave it off to provide isolation.
The second item is a complete validation of the wiring diagram I posted for the G3X system. All functions as intended. I did confirm with Garmin one add that might be desired. ADS-B weather and traffic from the GTX-45R to the main display(s) is by serial port with a dedicated wire. I have that wire in place for the PFD, but not the MFD. The PFD will not share the data with the MFD. In other words, connect a serial port from the GTX-45R to each display you want ADS-B In displayed.
Last update is still coming. I had a very steep learning curve configuring each device to properly communicate. I will update the wiring diagram with config information for each device as soon as I get a chance. Hopefully that will help anyone doing their own interconnects or upgrades.
Dues paid 2020
Old 02-05-2020, 02:59 AM
Default Now flying
Another update.
Now flying with 11 hours on the aircraft. Everything is working, talking and playing nice. The only issues I have had that are wiring related have been with engine sensors. I got lazy when I got that far and did not do pin out drawings since the hook up was per the Garmin GEA24 pin out drawings ?. what could be easier?
I hooked up the oil pressure and fuel pressure sending units to 12V instead of 5V destroying $200 worth of sending units. I also hooked up all of the CHT and EGT thermocouples reversed, because hey, red wires are always positive, right? No cost there, but some head scratching and research to find the reference for type K thermocouples polarity. My recommendation.. do the drawing!
The take away from this post is that the interconnect file I posted is correct for my set up, and hopefully, might provide a starting point for someone else. I still need to go back and add the configuration notes to the file and repost. Some day when I have more time.
Dues paid 2020
Old 02-05-2020, 05:59 AM
BillL BillL is offline
Originally Posted by leok View Post
Another update. <snip>
Congratulations on flight!! I found that time has not gotten more available after first flight.
Each homebuilt is a prototype, everything is not perfect! Keep us informed of your progress in the verification/validation phase.
You know what they say . . "there is a time in every project when you fire the engineers and go to production" or some variant of that.
Bill
Old 02-05-2020, 06:24 AM
KatanaPilot KatanaPilot is offline
So what do you do Bill when the producer is also the engineer?
Krea Ellis
Locust Grove, GA
DA20-A1 "Princess Amelia" - gone home to Amelia Island
RV-7A Phase 2
RV-10 under construction at Synergy Air South
