Old 02-20-2018, 06:47 PM
howzat howzat is offline
Default Sideslipping an RV
Being fairly new to RVs and the proud owner of an RV-7, I've not been able to get a consistent answer as to whether there are any restrictions or limitations on sideslipping on base or final to loose height. It's been suggested to me that it shouldn't be done, and/or shouldn't be done with any flap out. I'm not referring to a sideslip in the flare or short final in a crosswind, but something more sustained and likely at a (slightly) higher speed.
Any advice or guidance would be appreciated!
Old 02-20-2018, 06:54 PM
I sideslip my -6 frequently with full flaps all the way to the flare. I'm generally at 1.3x stall speed when I begin to come out of the slip. I've never experienced any adverse characteristics, and when I transition trained with Mike Seager (the factory transition CFI), he indicated that the RV-6 slipped very well and we practiced a few. An RV-7 could be different, but I doubt it.
Why not experiment at altitude to check the handling characteristics of your -7 with flaps, without flaps, and at different bank angles and speeds?
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 02-20-2018, 07:15 PM
Ed_Wischmeyer's Avatar
Ed_Wischmeyer Ed_Wischmeyer is online now
Who suggested that you not slip an RV? What reason did they give? How much RV time did they have? Did they ever try it themselves?
I used to slip my RV-4 all the time with full flaps as well as clean. Never paid attention to the speed in the slip, though, as my attention was outside. I slip the -9A when I have to, but slips don't do as much in the -9A as they do in other planes.
Kyle's got the right idea, go try it at altitude. Personally, I doubt you'd spin it, but that might happen, so go find an RV instructor and have at it!
Ed
RV-9A at KSAV (Savannah, GA; dual G3X Touch with autopilot, GTN650, GTX330ES, GDL52 ADSB-In)
Previously RV-4, RV-8, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
2020 dues slightly overpaid
Retired - "They used to pay me to be good, now I'm good for nothing."
Old 02-20-2018, 07:45 PM
Paul 5r4 Paul 5r4 is offline
And please post your results!
I use to do nearly full control deflection slips in my cessna. I've slipped my 7A a few times although nothing even close to the control deflections I did with the cessna. When slipping the 7A, I didn't notice any unusual characteristics.
Paul Gray
Foley, Alabama
N729PG..... 450+ hrs
RV 7A, Lycoming 0 320 D1A, Sensenich FP propeller
pilotforfun2001@yahoo.com
VAF supporter $$$
Old 02-20-2018, 07:53 PM
merlin3 merlin3 is offline
I have found slips in my rv are far less effective than the cessnas and pipers ive flown. Even with full rudder it just isnt that effective to me.
Justin
Rv-6, o360, whirlwind cs prop, old paint and panel
Rv-4,o-320,prince prop, mgl avionics screens - sold
Old 02-20-2018, 08:31 PM
airguy's Avatar
airguy airguy is offline
My 9A does not bleed energy nearly as well in a full slip as the 172, but with full flaps and a CS prop I really haven't needed it other than Phase I testing.
Greg Niehues - SEL, IFR, Repairman Cert.
Garden City, TX VAF 2020 dues paid
N16GN flying 650 hrs and counting! IO360, SDS, WWRV200, Dynon HDX, 430W
Built an off-plan RV9A with too much fuel and too much HP. Should drop dead any minute now.
Old 02-20-2018, 08:39 PM
RV6_flyer's Avatar
With a Constant Speed prop, the slipping is not always necessary BUT when one flys formation, sometimes it is needed. Over the past 20-years flying and more than 3,300 hours in my RV-6, I have slipped the aircraft MANY times including full rudder inputs. Very controllable and very similar to the 1XX series Cessnas but easier in the RV.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 02-20-2018, 09:12 PM
Bugsy's Avatar
Bugsy Bugsy is offline
Default It?s hard
It’s really hard to slip an RV at cruise speeds. That big rudder is really hard to push out into the wind. I have pressed on it at cruise, never hard enough to endure a true slip.
Paul 'Bugsy' Gardetto, Col, USAF (ret)
Milwaukee, Wisconsin (Timmerman Field)
N377KG - Flying (250 hrs)
RV-7A, Aerosport O-360, WW200RV
Advanced Flight 5400
Avidyne IFD440
Paint by planeschemer.com
Old 02-20-2018, 09:33 PM
Another RV-4 slipper here. I do it all the time with flaps down; I like remaining high until the runway's made.
Slips aren't as effective in an RV as factory planes simply because there's less, and cleaner, side area to add drag. Not *as* effective, but still effective.
Charlie
Old 02-20-2018, 10:27 PM
N941WR's Avatar
N941WR N941WR is offline
Try flying a -9 with a FP prop, you will learn to slip it. Although, as Ed said above, in the -9(A), it really doesn't do a whole lot.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
