Old 06-29-2020, 01:46 PM
AJPope's Avatar
AJPope AJPope is offline
Default Prop Lever
There have been several discussions prop levers moving forward when the throttle friction is loosened. Some have had luck with the longer Hartzell control arm. I have an MT governor and received no reply when contacting them. Everyone’s good buddy, Squaz, suggested a spring on the prop lever going back to the bulkhead. The angle bracket attached nicely to an existing bolt with a nutplate behind it. Works like a champ! (Turns out I didn’t need to remove the top panel on the throttle quadrant.)
https://n990bv.smugmug.com/Falcon-RV-Squadron/i-b6SrPCV
https://n990bv.smugmug.com/Falcon-RV-Squadron/i-9DsCRpg
https://n990bv.smugmug.com/Falcon-RV-Squadron/i-C6TbGgb
Falcon RV Squadron
RV-8
Superior XP360
Dual Pmags
G3X
Old 06-29-2020, 10:02 PM
ArlingtonRV ArlingtonRV is offline
That's a really cool idea. Where did you get the spring? Is there anything like a part number on it?
Steve Rush
Arlington, WA
ArlingtonRV on YouTube
RV-8 (Bought Flying)
Glasair Sportsman (Sold)
RV-8 Tail, QB Fuselage (Sold)
RV-4 (Bought Flying) (Sold)
RV-9 Tail
RV-12 120018 Flying (Sold)
RV-7 Tail, Wings, Started Fuse (Sold)
Old 07-01-2020, 06:32 AM
Southern Pete Southern Pete is offline
I have an RV-6 with a centre quadrant that suffered from the same problem. My solution is to use push-pull/vernier controls for prop and mixture. Overall I think it is a better solution, particularly when flying in formation.
Pete
Old 07-01-2020, 02:05 PM
AJPope's Avatar
It came from Lowe's (Aviation isle) It's on the bag in the second pic. 2 3/8" long. Shortest bracket you can find. I cut the spring down just a bit. If needed, I can put another hole closer to the bulkhead or drill a hole higher on the prop lever. Working great for now.
Falcon RV Squadron
RV-8
Superior XP360
Dual Pmags
G3X
Old 07-01-2020, 02:20 PM
Great, thanks.
Steve Rush
Arlington, WA
RV-9 Tail
