Wedgeloc Cleco shortage
jls32
Member
My Wedgeloc's have been backordered from Cleaveland since June with no end in sight.
1) Are Kwikloc's good enough?
2) Is there another supplier of Wedgeloc's? I searched but haven't found one.
Thanks!
Kwicloc
I hace used Clecoloc and Kwicloc, but have never had any Wedgeloc to try.
Kwicloc have been good enough, and better than Clecoloc. Occasionally I chuck one in the bin because it is faulty. Clecoloc seem to vary a bit between good batches and bad batches.
It sounds like there may be a bit of a wait for Wedgeloc so it may be worth investing in just enough Kwicloc to keep the build moving? You can never have too many clecos!
I recently ordered from Brown tool and the clecos that showed up we’re Clecoloc. They are ok for non final drilled holes but seem undersized for final drilled holes. I will be ordering wedgeloc ones when they are back in stock. The kwikloc ones I have are fine. I just ran out and needed more
