Go Back   VAF Forums > Main > RV Building Tips/Techniques
Old 07-14-2019, 11:47 AM
I-TERA's Avatar
I-TERA I-TERA is offline
I will add some more info and an attempt to approach the question from a quantitative point of view.
see : " consideration .." at the link below. https://www.dropbox.com/sh/49ialxn7q...QGuvddEca?dl=0
Claudio
Claudio Ricci
F1 Rocket EVO
Old 07-14-2019, 05:11 PM
Scott Hersha Scott Hersha is offline
Originally Posted by Stockmanreef View Post
Another random question: I am about to mount engine and the plans say that a washer may or may not be needed under the castle nut. So it is OK to have NO washer under the castle nut on the engine mount bolt?
I would say no. I think you need at least one washer under the nut since its going on the aluminum engine casing. I think what they mean is that you can add extra washers here if you need to in order to make the castle nut hole line up. Remember, the upper and lower bolts are not the same length on the dynofocal Lycoming engine mount.
SH
RV6/2001 built/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019 Flying
Cincinnati, OH/KHAO
JAN2020
Old 07-15-2019, 08:41 AM
flion's Avatar
flion flion is offline
I don't have the -14 plans but I checked the -6 plans (and the -10 even though it has different mounts) and the exact callout was AN-960-716 washer under nut as required. I admit the wording is a bit ambiguous but at least one washer is required; you may need another, thick or thin, to get the cotter pin in at torque.
Patrick Kelley - Flagstaff, AZ
RV-6A N156PK - Flying too much to paint
RV-10 14MX(reserved) - Fuselage on gear
http://www.mykitlog.com/flion/
EAA Technical Counselor #5357
Old 07-15-2019, 02:44 PM
Stockmanreef Stockmanreef is offline
A couple of washers were required to the the nut out far enough so that the cotter pin would be effective.
thanks
Ken Stockman
Midland, MI
EAA Chapter 1093 member
FaceBook Page: Ken's RV-14
RV-14a (serial number 140073)
N73XP
Plane at hangar and the wings ON.
