VAF Forums
VAF Forums (https://vansairforce.net/community/index.php)
-   RV General Discussion/News (https://vansairforce.net/community/forumdisplay.php?f=2)
-   -   Becker Transponder Garmin GDL-82 (https://vansairforce.net/community/showthread.php?t=167709)
BobRv4 01-11-2019 01:46 PM
Has anyone installed a GDL-82 with a Becker Transponder ATC-4401-1-175?
Did it work for you?
Did you get error code (on the becker) E10?
How did you fix it thanks.
The transponder works fine, until you power up the -82 then it throw a code.
simpkinsona 01-11-2019 02:56 PM
Compatible
I installed a GDL-82 with my Becker 4401. I had no issues. Have you found out what the error code means?
-Andy
simpkinsona 01-11-2019 03:31 PM
Bus
Mine is setup so the GDL-82 is on when I turn on the avionics bus. So it?s already on when the transponder is turned on.
BobRv4 01-11-2019 04:25 PM
E10
Best I can tell Ground Plane issue.
Did you use one of the recommended transponder antennas?
I'm using the single pole ones, going to try again then may order a new ant if it stills broke.
simpkinsona 01-11-2019 10:05 PM
Antenna
I looked up the error code. It says it?s an antenna problem. So it sounds like the transponder doesn?t like something in the cable or antenna. Maybe double check the proper connections for the transponder and antenna output.
I used the blade antenna already installed. I just ran the RG-400 to the GDL-82 and put on a new connector. I don?t know what the model number is for the antenna.
BobRv4 01-12-2019 01:46 PM
coax
Well, we "think" its fixed need to do the flight test in a few days.
What stop the error code was adding to the length of the RG400 coax (about 18" long) from the transponder to the GDL82. Replaced with about 6' of RG58 with a BNC male adapter to connect the two. Tried all different combos but this was the only one to work. Its now about 6' total length, RG400/connector/RG58. So that's the story now, time will tell......
RV10Man 01-16-2019 04:03 AM
-Andy
Where did you mount your GDL-82 in the airplane?
BobRv4 01-16-2019 07:49 AM
firewall
The box is mounted against the inside of the firewall. The GPS ant is mounted under engine cowl.
RV10Man 01-16-2019 12:56 PM
....Thanks!!
simpkinsona 01-16-2019 07:05 PM
Mounting
Mine is mounted on a center console between the rudder pedals. The GPS antenna is on the glare shield of my tip-up canopy.
-Andy
