VAF Forums
VAF Forums (https://vansairforce.net/community/index.php)
-   Engine Monitors (https://vansairforce.net/community/forumdisplay.php?f=58)
-   -   How do I get out of set ? EIS (https://vansairforce.net/community/showthread.php?t=151719)
mark manda 07-25-2017 01:45 AM
Hi,
I haven't been flying much, can't remember much. I can't get back to normal view after pressing two buttons and raising my fuel levels manually. On my GRT
Thanks for any input.
h&jeuropa 07-25-2017 04:45 AM
Press and hold the right button until the unit cycles through and the initial screen displays.
Funny, I had to look it up again this Spring. Must be old age!
Jim Butcher
mark manda 07-25-2017 07:53 AM
Thanks Jim-- I was holding different combinations down. And starting to change settings.
mark manda 07-25-2017 08:30 AM
I went and donated too. Time flies
Lars 07-25-2017 09:13 AM
If all you are doing is wanting to change the fuel level after filling the tanks, press and hold the right and left button simultaneously. That will take you to the fuel level page. Across the bottom you'll then see Up, Down and Next. Use the up/down buttons to set the fuel level to where you want it to be, then press Next and you'll return to your home page.
mark manda 06-28-2020 01:22 AM
Thanks Lars? I?ll do that? I thought I could hold down a certain combo and they would default to my full numbers.
lostinsuisse 06-28-2020 02:28 AM
To set the EIS fuel to your full setting
From page 6 of the Rev P EIS manual, section 3.2:
2. If the instrument includes the fuel flow option, review or update the fuel quantity setting as necessary. (Pressing the outer two buttons of the EIS will bring up the fuel quantity set page. While on this page, pressing the "UP" and "DOWN" (left and center buttons) will set the fuel quantity to whatever you have entered on the "MAX Fuel" setting on the configuration set pages.)
So press the outer two buttons then the left and center buttons and your fuel is set to your full setting. I think you will need to press another button to return to the default screen, but I've forgotten that bit.
-jim
mark manda 06-28-2020 10:56 PM
Thanks Jim
