VAF Forums
VAF Forums (https://vansairforce.net/community/index.php)
-   RV-12/RV-12iS (https://vansairforce.net/community/forumdisplay.php?f=73)
-   -   iS engine cushion clamp frustration (tip) (https://vansairforce.net/community/showthread.php?t=170173)
rcarsey 04-01-2019 11:30 AM
I received the engine last week and had it mounted up in no time.
Towards the end of this KAI section, they have you use 3 cushion clamps (MS21919's) all stacked on top of each other with one long AN3 bolt. You're securing two fairly thick wiring-harness cables to the powder coated engine frame, hence the need for THREE clamps.
I must have wasted a full hour trying to line up all the clamps, squeeze them, get the bolt through all of them.. very frustrating.
After careful inspection of the photo in the KAI, I noticed that the factory had compressed each clamp separately and used safety wire to keep them closed.
After closing/compressing, then safetying the three clamps separately, it was a lot easier to slide the AN3 bolt through all of them and get the nut on. Maybe everyone knows this trick already, but it blew my mind! I didn't realize that this thin safety had that much strength to hold a clamp shut.
Cammie Patch 04-01-2019 12:58 PM
Adel clamps have taken a lot of verbal abuse over the years.
Needle nose vice grips are handy to have too.
bkervaski 04-01-2019 01:04 PM
Or zip ties ... we used them to hold clamps together while fitting the hardware and then just clip them off.
bobg56 04-01-2019 03:26 PM
Run an awl thru and clamp with needle nose vise grips or safety wire..
Kyle Boatright 04-01-2019 03:41 PM
Hemostats are very helpful too.
But Adel clamps remain an instrument of torture. ;-)
RFSchaller 04-01-2019 10:47 PM
Darn! I thought the needle nose vise grips were a flash of genius unique to me!😝
