UHMW Bushings
mulde35d
Friend
So I am trying to trim the UHMW Bushings on Page 32-02 for an RV-14A and figured I would rough cut them with the band saw and final trim them with a belt sander. My belt sander is having one heck of a time trimming off the plastic and it is a pretty coarse grit (80 grit).
Is there a trick to trimming this stuff or is it just that tough?
And
I have also found that some abrasives are better than others. The cheapest ones usually do not perform anywhere near as well as the quality ones...
Solution
My biggest issue was a dull bandsaw blade. I changed the blade an cut right down the marked lines. Didn?t need much sanding after that.
