VAF Forums
VAF Forums (https://vansairforce.net/community/index.php)
-   Electronic Ignition Systems (https://vansairforce.net/community/forumdisplay.php?f=103)
-   -   SDS RPM Pulses per Revolution? (https://vansairforce.net/community/showthread.php?t=176828)
majuro15 11-11-2019 06:31 PM
I'm getting inaccurate RPM numbers on my AFS5XXX screens. I know I can adjust the settings but don't know how many pulses per revolution the SDS ECUs give off? Anyone know? I have the EM-5, full SDS setup.
rv6ejguy 11-11-2019 08:28 PM
3 pulses per crank rev. You can have a 5V signal from pin 12 (green wire) or 12V signal from pin 22 (yellow wire).
Mike S 11-11-2019 08:42 PM
Is this true for all units, or just the six cyl??
majuro15 11-11-2019 09:19 PM
Thanks Ross! So I am 90% I need the 12V so I have the yellow wires hooked to the EFIS. If I actually need the 5V, would that affect the value the EFIS is reading?
I'll try the 3 setting tomorrow. I did play with that a second today but feel like the EFIS was still reading high.
rv6ejguy 11-12-2019 06:07 AM
4 cylinder systems will deliver 2 pulses per crank rev.
rv6ejguy 11-12-2019 06:10 AM
Check the minimum trigger voltage on the EFIS for the tach pin you're using. The 5V could be too low to give an accurate reading.
