VAF Forums
VAF Forums (https://vansairforce.net/community/index.php)
-   RV-12/RV-12iS (https://vansairforce.net/community/forumdisplay.php?f=73)
-   -   Adding the Rudder Trim Tab (https://vansairforce.net/community/showthread.php?t=171447)
n74846 05-12-2019 07:54 AM
I am flying a legacy 12 (2014) that I did not build. I am adding the optional trim tab kit to a newly built rudder to replace the original rudder(a whole other story). I notice a pre-bent angle in the tab. Is this the recommended start point or should the tab be straightened and deflected as needed later? Thanks!
DHeal 05-12-2019 08:23 AM
I installed the trim tab as received from the factory and the angle was dead-on perfect for torque compensation. I have not had to adjust it since installation.
Tacco 05-12-2019 02:10 PM
Same here.
DaleB 05-12-2019 02:51 PM
Me three. Didn?t need to adjust it at all.
n74846 05-12-2019 06:44 PM
Thanks for the re-assurance!
Piper J3 05-12-2019 07:40 PM
Agree that Van's trim tab angle is correct for high-speed level cruise. You will need a couple of pounds of force on right rudder peddle in climb and lightly rest your foot on left rudder peddle in glide to keep ball centered.
