Sterba Prop Info
Zazoos
My 0-320 E2A 160 hp came with a Sterba 68x72 prop.
There really wasn't any information in the prop logbook.
Just curious about a few things.
1. What is the safe max continuous RPM?
2. I have not put wheel pants or fairing on yet, but I am see a speed of 130 kts at 2350 rpm while at 2500 feet. Seems a bit low. Would this be more of a climb prop? Or is this about normal?
3. What RPM should I see with a 160 hp?
Thank you,
Perfectly normal. Reconvene after installation of gear leg fairings and wheel pants. Significant speed and rpm increases are typical.
