Tail Spring Mounting Question
Surfdoc
Question for those who had to mount the tailspring mount during fuse construction. How did you do the following.
Many Thanks in advance!
1. The WD-409 forward plate upper edge should be used to square the tail spring mount with the F-711 bulkhead assembly. (How did you square it off?)
2. Drill through F-711 and WD-409 for the AN4 bolts using the pre-punched holes in F-711 as drill guides. (What method used for drilling out the weldment?)
3. Drill through F-712 and WD-409 for the two “keeper” rivets only; the three bolt holes will be match-drilled later while attaching the vertical stabilizer. (My VS does not have any holes to match drill on it)
