Freemasm
I’ve only seen horizontally oriented switches in aircraft that were ghetto’d up. You know, the one’s you’ve seen where switches seem arbitrarily placed usually the result of some retrofit, not enough space for typical orientation.
Electrical system will be dual redundant (left/right, not primary/secondary) buses; engine buses the same. Where the pilot has to select one vs the other (a two position selector switch, no off) such an orientation seems more intuitive than a vertical one.
Anybody witnessed/installed/experienced such? Sound reasonable or otherwise?
Said it was a dumb rookie question.
