I'm in the process of upgrading all the hoses on my RV9A that I purchased 3 years ago. Yesterday I attempted to remove the main gear leg fairings to replace the aluminum tubing brake lines with TS Flightlines brake lines. What I found appears to be fairings that are formed around the legs with no seam to remove them now. They are rock solid on the leg and appear to be filled with foam. The pic is from the floor skyward. I cannot find a wire attaching to a piano hinge. Anyone have advice for removing these without destroying the fairings and having to make new ones? If I do have to make new ones, is this a big job for a novice? Would the intersecting fairings have to be made over as well? Thanks in advance for any help.
