Precision Airmotive EX-5VA1
wirejock
The manual mentions an alternate outlet and that they can be swapped.
Does anyone know which port is the alternate outlet?
  • Fuel Servo EX-5VA1.pdf
Larry,
It's the port that doesn't have 90° AN4 elbow installed in it, 180° away from the installed fitting.
edit: picture attached, alternate outlet circled in red.
B
OUTLET
That's what I thought. On mine, that was where the outlet was installed and it was labeled "Outlet". I want to use the one 180 opposite.
Torque
OK. I got the fuel line and fitting installed but the torque value on the Precision Airmotive manual shows 45-50 lb in for the Fuel Line Union Nut on the Outlet Fitting
Is that correct? I can loosen the fitting with one hand. Seems like it will vibrate loose and spew gas everywhere.
