INJECTOR LINE
Most factory aircraft go from a 90 degree fitting on the divider, more or less straight down thru the inboard portion of the intercylinder baffle, with a baffle around the line at that point. Then inboard to the injector if bottom mounted or forward and inboard if front mounted.
