I've got a small annoyance with my installation. I have a Dynon Skyview HDX and an MGL V16 VHF transceiver with a Razor control head. I also have a Garmin GTR200 (COM1). I use a toggle switch to select which COMM radio talks with the HDX over RS232 (RX/TX). As I also have a N16 behind the Razor control head, the devices are all set to SL30 emulation.
My problem with this is that if I have the Razor (COM2) selected with the toggle and I try to set the COM standby frequency to 122.875 from either the HDX or the Razor, the frequency gets truncated to 122.800. I cannot set that frequency unless my toggle is set to COM1 and I set it from the Razor.
I've posted this question on the MGL forums, but since this involves two different manufacturers, I'm expecting a bit of back and forth. Maybe someone here has run into something similar.
Any ideas?
Any ideas?
