Stevehaley
Member
One of my flaps is higher than the other which is causing the plane to roll to the right. If i measure with a vernier from the centre of the line of rivets on the top front of the flap to the trailing edge of the main wing i get 6.78mm on port and 2.96 on starbd.(see pic) I think the port is correct as it aligns and stbd is high as it is 3-4 mm above the aileron when aligned with tip.
but if anyone can give me their equiv measurements would be grateful
As i didnt build the aircraft i dont have the templates to align the ailerons/flaps. However my understanding is that if the flaps are level with ailerons and the ailerons are level with the tips then that is correct?
