Where did you locate your defog/avionics cooling fans? How would you change the location based on your experience?
I'm in the Midwest where we get all four seasons, so I anticipate that they'll be defoggers in the winter and avionics coolers in the summer.
I have two Noctua 80mm fans that I planned to place halfway fore-aft between the sub-panel and panel rivet lines, and 9" outboard from center on each side (2/3 of the distance between the center and outboard rivet lines).
At OSH last month, I noticed that the Van's -10 has them closer to the windscreen and closer to the center.
