Try grabbing the first coil of the spring with a pair of longnose pliers, then twist in a direction that will “wind” the spring tighter ( In the direction of the wind). This should decrease the diameter and loosen it from the sides of the hose.
This is what works .
Spraying a bit of soapy water inside the hose can also help if you still have trouble (just rinse it out well with just water when finished).
