Getting to the point with my zip tips that I need to epoxy the rib that holds the light bracket to the inside of the wing tip. Question for those that have gone in front of me is did you epoxy directly or did you add extra glass around the edges?
I didn't epoxy the rib in place, but rather attached it with countersunk #6 screws and nutplates, spaced between the wing attach screws. Makes for easy removal if necessary.
