ron sterba
Getting closer to start up date this summer. (Dynon Skyviews) Where did you put your Transponder,ADSB and com antennas? Were they just mounted through the fuselage skin OR did you use a backing plate riveted to the fuselage ? My thoughts are comm just under baggage floor or just aft a foot and off center from exhaust. Closer to a rib support for rigidity. Transponder near wing tunnel and 6" inches in from fuselage edge. ADSB up front and to the right just behind co-pilot pedals maybe 3"aft of the firewall. My second thoughts for the Transponder and ADBS just 3" inches forward of the gear weld (RV9A). This way i could route my RG400 cable up along the side. I made a floor to put sound proofing in and this allows me to run wires under the floor to the panel. (I have mufflers and a 3 blade Catto prop, I want my machine QUITE! I did the DRAGSTRIP THING years ago. (Whatcha say, if you get my drift). I want it like a space capsule drifting thru space!
Always appreciate your thoughts
RV9A N421HJ Next number after the first Honda Jet! N420HJ!
Ron in Oregon
Ron in Oregon
