KSMurchison
I'm New Here
The question has been asked in the past without response. For those of you with a Ray Allen servo mounted inside the Aileron, how did you route the wires out of the aileron?
Scott Murchison
Lillington, NC
RV-4 Wings almost done
Former Hog /Viper Driver
On my RV-6, I ran the wire through the same bay as the torque tube to the aileron. I just drilled a hole and put a grommet in it. Inside the wing, I ran a short piece of flexible tubing that was tie wrapped to the rib. From there, it entered by normal wire runs that ran between the root and the top of the wing.
