My buddy and I both have that exact Whelen power supply in our planes. Coincidentally, we both were having problems at the same time. His was popping fuses occasionally--it turns out the switch was loose on the panel and one of the contacts was apparently shorting out and blowing the fuse. Mine had a separate issue with the ground which was easily corrected.
My point is that the Whelen unit may not be bad. With the Whelen power supply isolated, do you have good power going to it at the plug? If it's still blowing the fuse and the Whelen unit isn't even plugged in, then a supply wire upstream is likely chafing or has an exposed connection somewhere. That's a much less expensive fix.
