C chewton Member Jan 19, 2005 #1 how much offset/or difference in measurment from tips of horizonal stab to center of vertical fin. or do i just center spar on atach bracket seams to be about 1/4 of adjustment. what did others do. thanks bob mcmillin 90825 rv-9
N N523RV Well Known Member Jan 19, 2005 #2 DWG 27A in View A-A calls for a second AN950-10 washer to be glued to the aft side of the elevator stop to set the offset. I just stuck the washer on there and let the nose of the VS settle where it may. Matthew RV-9A Finish www.n523rv.com
