Warbirdsolutions
Is anyone aware of a tach transducer that would attach to the standard mechanical tach output on a Lycoming engine that would be compatible with Dynon products?
Brad
Also interested
Since I am dead on one side with my Surefly mag. Currently picking off the tach signal from my p-leads at the key switch.
Ron
the vans unit does work with a skyview. i ran it for a while when I first installed my skyview.
bob burns
RV-4 N82RB
The suggestion to use the Van's and UMA senders is a good one. BUT... I had two of them fail in quick succession when mounted directly to the accessory case. I bought a 12" tach drive cable from ACS and mounted the sender to a bracket on the firewall where it has happily lived for the past decade without a hiccup.
