chiricuca
I have pruchased th propeller 3F0M7/C68NF-0 and I noted that the bolts have not any hole for wire safe and it catches my attention. Is this normal? How can I assure that it won’t be loose?
Uses Nordlock washers maybe. What is on my Whirlwind GA prop. Look them up. I use on brake calipers too. Safe, save a lot of work
Thank you so much for the answer. I don't know these washers are so good for this application.
