sundog04
Member
I am building a 7A, fixed prop, carburetor. I would like to use metal eyeball carry through devices rather than rubber grommets for the engine control cables. How critical are the specified penetration locations. In the plans the carb mixture cable passes right next to the fuel pump doubler plate. If I moved the location 1/2 inch to center to make room for the eyeball, would it create a problem? How have others worked around this?
Mike Morris
[email protected]
