propflipper
Hello All. So here comes a rookie question, but I cant seem to find an answer in the finish kit contents list. I know wheels and brakes are included in the finish kit . But does "brakes" include the brake master cylinders as well ?
Thank you
Yep..and more
Everything for the brake system is, or at least was, in the finish kit. Now, let me make a suggestion if the brake system is your only question...Since I must assume you are in the building stage, install all SS braided lines and AN fittings in lieu of the supplied plastic tubing and save headaches down the road. The plastic works fine, but can cause issues down the road. When I built my -4, it was possible to call VANS and have any item you didn't want to be eliminated from the kits and the cost subtracted.
Call van’s thay can send you a pdf file with a parts list of all items in the finishing kit.
Hope this helps.
RD
