I don't know exactly how much mine draws at full load, but I can tell you the motor drew 800 mA with no load.briand said:How many amps does the actuator draw at approx. full load?
Quick question -Rosie said:
tysonb said:Quick question -
Why did you choose to keep both sides of the motor at 12v and switch the ground vs. keeping the motor at ground potential and switching 12v?
With the relays/motor wired as they are if one wire leading from the com->motor or coil->switch becomes chafed and grounds out the motor will run or pop the breaker (depends on the fault).
I'm a controls engineer by trade so I look at relay/motor circuits for possible faults that could potentially lead to a safety issue. I'm not trying to criticize as obviously it hasn't been a problem for your or Dan, but I'm just curious why it was done this way to begin with.
I would feel better with it wired like this:
The worst that would happen if a wire grounds out with it configured this way would be a popped breaker.
Now, the possibility of the wire becoming chafed in flight is pretty remote as long as it is properly secured, but it sure would be surprising to have the flaps extend in cruise when you least expect it...
Discuss please, if my interpretation is wrong or if this is a best practice thing I'd like to know.
Mark Burns said:Tyson,
I see this 'switching the ground" quite often in aircraft wiring. I've asked an engineer who designs aircraft circuits and frequents this site and he didn't have a good answer either!
justinmg said:Can I retain the panel switch with this?
I'd be curious to know exactly how many RV's have been lost to or experienced inadvertant flap deployment with the flaps rigged to a momentary toggle switch. The reality is with such an arrangement, you have to physically depress the toggle for several seconds to fully cycle the flaps one way or the other. To do it "inadvertently" is like trying to beat a freight train to the RR crossing in your auto and hitting the 26th car!DanH said:.....Why do you need flaps wired to a grip switch?
Side issue; inadvertent extension becomes very unlikely with a panel toggle. There are times when it could kill you.
Rick6a said:To do it "inadvertently" is like trying to beat a freight train to the RR crossing in your auto and hitting the 26th car!
briand said:How many amps does the flap actuator draw at approx. full load?
Gsuit said:Anyone have pics or schematic of how to have both: stick switch and panel mounted backup?
