Upper tolerance for rivet head height
RV701775
I am riveting the stiffeners on the elevators which call for a AN426AD3-3.5 rivets. This appears to be the correct rivet size but the head heights are coming out a bit high (0.065 in), while the milspec calls for an upper head height of 0.050 in) I have driven these until the rivet gauge hole is a tight fit which is more than 1.5 diameters and they are still high. Is this acceptable? I would rather not over drive them even more.
Just me
My thought is if they meet the min dia spec after driving,and they are taller than the min spec, they are good. I think the only trouble with longer than desired rivets are that they tend to bend over and clince. I have used longer rivets than called out several times just to be sure. Most of the time, the bigger the shop head, the better, but I dont mean to excess.
