rccpilot223
Member
Trying to install rod-end bearings into my elevator front spars for initial connection to HS. One of the REB's threads into the front spar nut plate about 1.5 - 2 turns and then "let's go". I can't seem to get the REB to screw into nutplate. Given everything is pre- and match-drilled, I THINK I assembled and riveted everything square. So only thing I can think is maybe a little warp in the nutplate.
Don't want to damage either the nutplate or the rod-end bearing. Wondering if there's any advice here on a way to get that threaded end of REB to screw in without damaging either component.
Thanks in advance for your help!
